link:
http://www.alfaholics.com/parts_by_car/ ... tial_part/
Reconditioned (new syncros etc.) gearbox on - exchange £425.00
Syncro ring £26.00
Syncro sleeve - reproduction - We recommend use of original Alfa Romeo item below only. £38.00
Syncro sleeve - original Alfa Romeo £65.00
Bearings
Note: due to the different method of location it is possible to replace late bearings with early - but not vice-versa
Input shaft 101.00.13.223.00 (early type ret. by clip) £54.00
Input shaft 105.12.13.223.00 (late type ret. by nut) £79.50
Input shaft (needle roller) 101.00.13.222.00 £7.50
Layshaft front (1300/1600/1750) 101.00.13.224.00 £39.50
Layshaft front (2000) 105.12.13.224.00 £45.00
Layshaft middle 105.12.13.224.00 £28.00
Layshaft rear 2900.60734 £28.00
Mainshaft front (1300/1600/1750) 101.00.13.223.00 £54.00
Mainshaft front (2000) 105.12.13.223.00 £79.50
Mainshaft rear (1300/1600/1750) 1358.16057 £22.00
Mainshaft rear (2000) 105.12.13.910.00 £22.00
5th gear needle roller £9.00
Front oil seal - cable clutch £4.50
Front oil seal - hydraulic clutch £3.00
Rear oil seal - cable and hydraulic £3.75
Gearbox rear mount £9.00
Gearbox rear mount/bush for early 105 & 101.
Correct more solid bush also used as heavy duty item for late 105. £21.50
Gearstick rubber gaiter - inner Click to see photo £6.50
Gearstick rubber gaiter - middle £8.50
Gearstick rubber gaiter - combined type - 2000 GTV only Click to see photo £12.00
Gearlever rubber seal - between top washer and rings £3.00
Gearknob - original black - screw on (for push down reverse cars) Click to see photo £38.50
Gearknob - original black - push on (for non push down reverse cars) Click to see photo £28.50
EDU! Alfahoolikud suudavad kõikvõimalikud jupid tarnida kõigile 105/115 seeria sõidukitele (ja üldse mitte nii kallilt)
TRK näiteks suudab need kõik ka autosse suruda
Käikude ragin võib olla tingitud aga ka õli puudumisest
EDIT. huviliste püüdmiseks on vaja eelkõige müügikuulutust ja pilte
