alfa 166
Tee juhiuks lahti, all paistab kaks-kolm pedaali, kõige parempoolsem on gaasipedaal. Nüüd mine veel lähedamale, uuri, kas juhtmed lähevad külge või ei.
Kui lähevad siis on võimalus et elektrooniline :mrgreen: :icon_wave:
aga ma olen suhteliselt kindel et on elektiline.
:icon_think: Gaasipedaali mõtlesid ikka wää?
155, 2x166, 159 ja 75?
alfa 166
ok
tegelt mul sellega selline mure et kui panen autol gaasi põhja siis üle 1300 pöörde ei lähe
ja kui panen draivi sisse ja anna gaasi siis selline tunne nagu auto ei saaks bensiini kätte :S milles võib probleem olla ?
alfa 166
Aga milles siis?
juhtus nii et auto seisis paar nädalat külma käes ja siis kui käivitasin võttis alguses 5 pütti taha ja peale nats aega käimist töötas korralikult aga gaas hakkas jamama :S
alfa 166
Kuidas sul ingliskeelega lood on? Võimalik et on ikkagi pedaaliasendi anduri pistiku juures mingi kala. Aga proovi ennem Aju resetti:
just to let you know i have had the same fault on my 166 i bought a new potentiometer from a member here andit didnt do anything for me. what i did in the end was just reset the ecu. if you have the original key dissconnect the battery and turn your lights on to make sure of a full drain down, then reconnect turn ignition on for 90 seconds or so then turn off for 90 secs then turn the engine over donnot rev untill it heats up and the fan comes on. then turn off. This worked for me now when i take it to an mot station im going to drive it like a ***** as you may know the ecu sets to how you drive i cant wait to get it to mot and drive the baby.
Hi all, this is an old thread, but I had a problem with my engine before christmas, it wouldnt rev at all, I have a 3.0. anyways , the car was laid up until since then , and my local mechanic had a look at it and diagnosed a faulty potentiometer. (which would cost € 500 new from a MD) anyhow, i serached the site and found this thread. I did the ECU reset and the engine is now flying. Im over the moon!!
SO im just posting this message to thank everyone on the thread , this is a brilliant site thanks everyone paul
http://www.alfaowner.com/Forum/alfa-164 ... t-rev.html
PS: järgmine kord otsid ise sealt infot! :icon_roll:
