PUTERDAB
#21. Disconnect the negative lead from the battery for a minimum of 45 minutes. Some people recommend overnight but that is not really necessary.
2. Reconnect the battery negative lead
3. Put key in ignition, turn to MAR and leave for 90 secs
4. Turn off the ignition, but not remove the key and leave for 90 secs
5. Start the engine but do not touch the throttle and let the car idle for 15 mins otherwise the car will not rev freely afterwards (as V6 owners know at their peril)
6. Turn the car off and leave for 10 mins
7. Start the car and take her for a blast
Note:
normal bold text = ECU Reset
bold and italic and underlined = Throttle reset
EDIT: 3,4 punkti peaks allajoonitud olema ja kogu tekst peaks "bold" olema
Note:
