Inglisekeelsed terminid Giulietta kataloogis - Help!
Posted: 18 Sep 2010, 20:58
Tere sõbrad
Selline lugu, et meil siin Giulietta kataloogi tõlge parasjagu valmimas ja tõlkija (vaeseke) ei tea kuidas ilusasse emakeelde teatud väljendeid ja lauseid panna.
..ja naine nagu ma olen, teda ka aidata ei oska :icon_problem:
Panen siia tõlget vajavad laused üles - hirmus tänulik oleks kui te kaasa mõtleks ja aitaks kataloogi lugejale paremini mõistetavaks teha :icon_roll:
1) The new floor pan is a veritable system in its own right that interacts synergetically with each individual mechanical and electronic component on the car to guarantee agility, comfort and safety. The four technologies that give rise to the Giulietta's unique approach to the road stem from this system. These include DUAL PINION active steering, ADVANCED MACPHERSON front suspension and MULTILINK rear suspension, plus ALFA ROMEO DNA
2) A third load line increases the energy-absorbing capacity of the front end and reduces both inertia forces and intrusions into the passenger compartment.
3) 35% more maximum power due to the adoption of a cam profile designed for high performance
4) more torque at low speed through direct control of valve lift.
5) Pick-up improved by up to 12% due to high air mass pressure.
6) Continuous dual variable valve timing
7) “Scavenging”, a revolutionary control system that does away with turbo lag.
8.) Bore and stroke / Displacement cc / Distribution (control)
9)Advanced MacPherson with aluminium pillar, hollow anti-roll bar fitted on connecting rod
10) Multilink with auxiliary frame and aluminium wishbones and anti-roll bar
11) Toothed belt with hydraulic tappets with fixed timing
12) Toothed belt with hydraulic tappets and intake side MultiAir system
13) MPFI supercharged through exhaust gas turbocharger with intercooler
14) Two continuously variable valve timing units and toothed belt with hydraulic tappets
15) Direct petrol injection and turbocharging with scavenging system and intercooler
:thanksspin: :thanksspin: :thanksspin: :thanksspin: :thanksspin: :thanksspin: :thanksspin:
