Inglisekeelsed terminid Giulietta kataloogis - Help!
Tere sõbrad :)
Selline lugu, et meil siin Giulietta kataloogi tõlge parasjagu valmimas ja tõlkija (vaeseke) ei tea kuidas ilusasse emakeelde teatud väljendeid ja lauseid panna.
..ja naine nagu ma olen, teda ka aidata ei oska :icon_problem:
Panen siia tõlget vajavad laused üles - hirmus tänulik oleks kui te kaasa mõtleks ja aitaks kataloogi lugejale paremini mõistetavaks teha :icon_roll:
1) The new floor pan is a veritable system in its own right that interacts synergetically with each individual mechanical and electronic component on the car to guarantee agility, comfort and safety. The four technologies that give rise to the Giulietta's unique approach to the road stem from this system. These include DUAL PINION active steering, ADVANCED MACPHERSON front suspension and MULTILINK rear suspension, plus ALFA ROMEO DNA
2) A third load line increases the energy-absorbing capacity of the front end and reduces both inertia forces and intrusions into the passenger compartment.
3) 35% more maximum power due to the adoption of a cam profile designed for high performance
4) more torque at low speed through direct control of valve lift.
5) Pick-up improved by up to 12% due to high air mass pressure.
6) Continuous dual variable valve timing
7) “Scavenging”, a revolutionary control system that does away with turbo lag.
8.) Bore and stroke / Displacement cc / Distribution (control)
9)Advanced MacPherson with aluminium pillar, hollow anti-roll bar fitted on connecting rod
10) Multilink with auxiliary frame and aluminium wishbones and anti-roll bar
11) Toothed belt with hydraulic tappets with fixed timing
12) Toothed belt with hydraulic tappets and intake side MultiAir system
13) MPFI supercharged through exhaust gas turbocharger with intercooler
14) Two continuously variable valve timing units and toothed belt with hydraulic tappets
15) Direct petrol injection and turbocharging with scavenging system and intercooler
:thanksspin: :thanksspin: :thanksspin: :thanksspin: :thanksspin: :thanksspin: :thanksspin:
alfagirl wrote:These include DUAL PINION active steering and MULTILINK rear suspension
Elektromehhaaniline roolivõimendi
allikas: http://www.bmw.ee/newbmw3coupe/efficien ... .html#more" onclick="window.open(this.href);return false;
Kindlasti tasuks vaadata sõlme ennast, et ta tõesti on elektromehhaaniline, otsetõlge oleks ju topelthammasratastega aktiivroolivõimendi... küsimus on kas itaalja inseneer taipas aktiivseks sõlmeks sinna panna elektrimootori...
NB! Nõrga aku laetuse korral seda tüüpi roolivõimendi võib anda ootuspärasest nõrgema tulemuse ;) Jälle areng paremuse poole peetud autode turule mõeldes :D
__
Mulitlink on ka eesti keeles multilink, kuigi on kasutusel ka termin MITMIKHOOB / Vali ise kuidas tõlgid, multilink tagavedrustus või MITMIKHOOB ehk koguni MITMIKHOOVALINE tagavedrustus.
(umbestäpselt sama asi mida VAG rakendas 15 aastat tagasi esisildades ja mida kiruti kui lagunevat kräppi, ning asuti neid hoobasid seal jämedamaks tegema kestvuse huvides - kuigi algne idee oli palju peenikesi ja kergeid hoobasid, saavutamaks võimalikult vähest vedrustamata massi)
Nii mina olen oma panuse andnud - TS teeb lõpu ära!
hästi lampi pakutud (ehk siis vajab tugevat keelelist ülevaatust)
Uus põhi on omaette süsteem, mis suhtleb eraldiseisvalt kõigi mehhaainiste ning elektrooniliste komponentidega, tagades nende koostöös parima jõudluse, mugavuse ning ohutuse. Giulietta teetunnetuse( :?: ) peamiseks aluseks on neli tehnoloogiat, mis kombineerituna annavad unikaalse koosluse. Nendeks on kahekiiruseline elektriline roolivõimendi, täiustatud MacPhearsoni esivedrustus, mitmikhoobadega tagavedrustus ning Alfa Romeo DNA (siia kirjutaks DNA kah lahti)
Täiendav ohutustala suurendab esiosa neeldumisvõimet ning vähendab salongini jõudvat löögijõudu.
35% rohkem jõudu tänu suurendatud jõudlusele suunatud nukkvõlliprofiilile
suurem väändemoment madalatel pööretel tänu klapitõusu kontrollsüsteemile.
MIlle kohta see käib :?: :?: :?:
Pidevalt muudetav klapiajastus (nii sisse kui väljalaskeklappidel)
Unikaalne süsteem, mis vähendab turboviivet (nime paku ise- tegelikult on tegemist süsteemiga, mis hoiab heitgaaside survet üleval)
Silindri mõõt, kolvikäik / töömaht / klapiajam
Täiustatud MacPhearsoni püstik koos stabilisaatorvardaga (pildilt paistab muidugi midagi huvitavamat)
Mitmikhoobvedrustus täiendava raami ning alumiiniumist õõtshoobade ja stabilisaatorvardaga.
Hammasrihm ja hüdrotõukurid, muutumatu ajastusega.
Hammasrihm ja hüdrotõukurid ning sisselaske poolel MultiAir süsteemiga
Mitmikpunktiga sissepritse koos turbiini ja vahejahutiga
Hammasrihm ja hüdrotõukurid ning kaks pidevalt muutuva klapiajastuse juhtseadet
Bensiini otsepritse ja vahejahutiga turbiin koos "selel asjaga, mida eelpool peaks nimetama"
:icon_think:
no ei kujuta ette, mida sellega öelda tahetakse- pick up all mõeldakse ilmselt gaasipedali nullseisust väljatulekut (ainus asi, mida õhk võiks abistada aga... 12% peaks siis käima reaktsiooniaja kohta mitte õhumassi kohta)
pagana keeruline :-)
pakuks siis vasteks midagi sellist, et:
mootori 12% kiirem reageerimine tänu paremale õhuvoolu kontrollile :roll:
alfagirl wrote:
spark wrote:kas homme saab juba näppida :captain:
kaunitar läheb meil otse tartusse praegu.. näha ja silitada saab teda Tartu Motoshowl reedest pühapäevani, peale seda peab salongi tulema külastama kui igatsus suureks läheb..
ma nii lootsin, et saab kasvõi korrakski kiigata (n.ö. sniikprevjuu) :(
