M: JVC KW-XR411 Double Din Stereo
Brand: JVC
Condition: Brand New
Product Description: JVC KW XR411 - radio / CD / MP3 player / digital player
Product Type: Radio / CD / MP3 player / digital player
Dimensions (WxDxH): 18.2 cm x 16 cm x 11.1 cm
Weight: 1.8 kg
Form Factor: Double-DIN - in-dash unit
Sound Output Mode: Stereo
Equaliser: Parametric - 3-band
Response Bandwidth: 40 - 20000 Hz
Max Output Power / Channel Qty: 50 Watts x 4
Amplifier Output details: 20 Watt - 4 Ohm - 40 - 20000 Hz - THD 1.0% - 4 channel(s)
Radio: Radio tuner - FM/MW/LW - 24 preset stations
CD System: CD / MP3 player - 5 - 20000 Hz
Digital Player (Recorder): Digital player
Technical Details
Main Specifications
Weight: 1.8 kg
Extended Specifications
General
Depth: 16 cm
Height: 11.1 cm
Recommended Use: Car
Weight: 1.8 kg
Width: 18.2 cm
Audio System
Equaliser: Yes
Features: Telephone mute, CD Text capable, ID3 tags support, iPod ready
CD System
CD-R/CD-RW Compatible: Yes
Media Load Type: Slot-load
Response Bandwidth: 5 - 20000 Hz
Signal-To-Noise Ratio: 98 dB
Supported Digital Audio Standards: WMA, MP3
Type: CD / MP3 player
Connections
Connector Type: 1 x audio line-out ( RCA phono x 2 ) ¦ 1 x audio line-in ( mini-phone stereo 3.5 mm ) ¦ 1 x USB ( 4 PIN USB Type A )
Features: USB flash drive playback
ID3 Tags Support: Yes
Equaliser
Equalizer: 3-band
Radio
Additional Features: FM stereo/mono switch
AM Preset Station Qty: 6 preset stations
FM Preset Station Qty: 18
Preset Station Qty: 24 preset stations
Tuner Frequency Range: FM: 87.5 - 108 MHz, LW: 144 - 279 kHz, MW: 522 - 1620 kHz
Type: Radio tuner - FM/MW/LW
Kontakt:
Allan Siimann
allan@bcstar.ee
55995192
Tallinn/Viimsi
Hind: 170 euri
Müügi põhjus: Tundub, et internet ei olegi alati tõde täis. Nimelt otsisin enda Ford Focusesse double din raadiot ja täna proovides selgus, et sinna läheb ikkagi 1,8 din :(
