Year - 1987
Make - Alfa Romeo
Model - 33
Engine Location - Front
Drive Type - Rear Wheel
Body Material - Steel unibody
Engine
Engine Configuration - V
Cylinders - 6
Aspiration/Induction - Normal
Displacement - 152.00 CU IN. | 2491.3 cc. | 2.5 L.
Valvetrain - SOHC
Horsepower - 150.00 BHP (110.4 KW) @ 5500.00 RPM
Torque - 150.00 Ft-Lbs (203.4 NM) @ 3200.00 RPM
HP / Liter - 60.0 BHP / Liter
Bore - 3.46 in | 87.9 mm. | 0.1 m.
Stroke - 2.69 in | 68.3 mm. | 0.1 m.
Compression Ratio - 9.0:1
Transmission Information
Gears - 5
Transmission - Manual
Dimensions
Seating Capacity - 4
Steering - Rack and Pinion
Minul vajus igatahes karp lahti
